First, sorry for my reply in English but as most of information for TZ4K14 tractor is in Czech or Russian and as I speak none of them I am trying to find some help in English or using google translate .
My tractor got new cylinder, piston, piston rod, new bearings, new oil and fuel pump. Now the engine speed is very high even if the gas is on the minimum position and it smokes a lot (white smoke). I can only shut off the engine when I keep force on the gas lever when it's in the minimum position. Where to start solving the problem?
Could it be the centrifugal regulator? The pressure on the spring is too strong and the weights of the regulator do not spread and the engine constantly tries to add more throttle? As far as I have read with google translate there are no suggestions how to adjust the spring?
(At first it smoked very heavily and a lot of oil/fuel came out from the exhaust. First I thought it might have been the oil that I poured directly to the piston rod bearings when installing the engine together, I might have added it too much there but I don't think that it can cause the high engine speed because the oil will circulate away from there? So it's probably unburned fuel that splits out thorugh exhaust)
TK 4-14 otáčky motoru
Přejít na
- Domácí výroba
- ↳ Traktory domácí výroby 4x2
- ↳ Traktory domácí výroby 4x4
- ↳ Traktory domácí výroby -kloubové
- ↳ Stavíme traktor domácí výroby
- ↳ Traktory od sousedů
- Seriová výroba
- ↳ Traktory sériové výroby -ZETOR
- ↳ Zetor 15/25
- ↳ Zetor Super 35-50
- ↳ Zetor 2011-4011
- ↳ Zetor 2511-5645
- ↳ Zetor 4712-6745
- ↳ Zetor 4911-6945
- ↳ Zetor 5011-7045
- ↳ Zetor 5211-7745
- ↳ Zetor Horal Systém
- ↳ Zetor 8521- 10540
- ↳ Zetor Proxima
- ↳ Zetor Forterra
- ↳ Zetor 80 Crystal+
- ↳ ZTS
- ↳ Technické problémy Zetor
- ↳ Motory Zetor
- ↳ Kuriozity, zajímavosti, tisk ZETOR
- ↳ Nesériové ZETORY
- ↳ Traktory sériové výroby - ostatní
- ↳ Evropské stroje
- ↳ Východoevropské stroje
- ↳ Americké stroje
- ↳ Asijské stroje
- ↳ Zahradní malotraktory
- ↳ Traktory sériové výroby - TK, MT
- ↳ Naše malotraktory
- ↳ Příslušenství k malotraktorům
- ↳ Ostatní
- ↳ Traktory sériové výroby - jednoosé frézy
- ↳ Traktory sériové výroby - lesní stroje a bagry
- NASETRAKTORY.cz
- ↳ Problémy s fórem
- ↳ Vlečky a jiná příslušenství
- ↳ Galerie
- ↳ Lesní a dřevo technika
- ↳ Dopravní technika
- ↳ Manipulační technika
- ↳ Polní technika
- ↳ Luční technika
- ↳ Ostatní technika
- ↳ Můj strojový park
- ↳ Srazy a setkání
- ↳ Motory
- ↳ Převodovky
- ↳ Nápravy
- ↳ Brzdy
- ↳ Kola a pneu
- ↳ Hydraulika
- ↳ Elektrika
- ↳ Mechanika
- ↳ Ostatní
- ↳ Zetor
- ↳ Ostatní
- ↳ Auto Moto koutek
- ↳ Dům a stavba
- ↳ Stroje a zařízení
- ↳ Koníčci, sběratelství a další zájmy
- ↳ Naše farmy
- ↳ Zahrada
- ↳ Zvířata, chovatelství
- ↳ Putyka
- VIDEO
- ↳ Videa našich strojů
- ↳ Videa z netu
- Inzerce
- ↳ Prodám
- ↳ Koupím
- ↳ Inzerce z www
- ↳ Služby a výpomoc
