Mitsubishi MT 22
martinto
Re: Mitsubishi MT 22
#91 Nový příspěvek od martinto »
spátečku z prídavného rozvádzača mám tu
len vymeniť šrób a pridať tesnenie
zatiaľ to funguje bez problémov
smoolae
#92 Nový příspěvek od smoolae »
martinto píše: stř led 31, 2024 5:13 pm spátečku z prídavného rozvádzača mám tu
Awesome, thanks for the pics!
smoolae
#93 Nový příspěvek od smoolae »
honzaPP píše: stř led 31, 2024 4:33 pm I don't think that any od your theory Is right. Both bolts at the botom are for oil draining. The tank oil plug should be somewhere higher....
Are you sure about thing with pressure oil? The part you pointed seems there is something inside.... Maybe someone else can say what it is. But definitely when you want to add a hydraulic circuit you must do it according to the pictures in the page I've sent you. I don't think you will find just ,,plug and play,, solution as you just think.
On mine Hinomoto there was just a small cube which I could remove and connect on the pipe threads which were left after that. So the pressure oil goes into new hydraulic switchboard and then back into the original pipe which goes to original switchboard. And then just add the tank oil hose to the plug in crankcase.....
Yep, it's indeed a drain plug. Will do as martinto did for the return.
But the "thing" under the tractor's right step board is indeed between the high-pressure oil line. Just re-checked it and traced the pipe back to the hydraulic pump's high-pressure output.
Will provide update when we start placing the hydraulics (probably in summer).
ladiki
#94 Nový příspěvek od ladiki »
Hi Smoolae,
What are You from? Is it thruth Estonia?
Do You know Russia forum? They have a lot of information and solutions about grey japaniess tractor...
smoolae
#95 Nový příspěvek od smoolae »
ladiki píše: stř led 31, 2024 10:25 pm Hi Smoolae,
Yes, I'm from Estonia.
But I don't really understand Russian. If you know any forums I would be happy to look them up 8) .
kronholec.sk
#96 Nový příspěvek od kronholec.sk »
Nazdar chlapi. Aký olej do prevodovky + hydraulika?
kronholec.sk
#97 Nový příspěvek od kronholec.sk »
oco13
#98 Nový příspěvek od oco13 »
Pekná micina, bol si v Novej Bani? 8)
martinto
#99 Nový příspěvek od martinto »
ja som dával MOL Farm JD len v zime ho musím nechať zohriať lebo svieti kontrolka upchatý hydraulický filter keď pridám plyn :vztek: :'(
Peter768
#100 Nový příspěvek od Peter768 »
O olejoch tu bola debata dávnejšie.... Ak máš mokré brzdy treba vybrať správny olej UTTO...je vhodný aj do prevodovky aj do hydrauliky.
kronholec.sk
#101 Nový příspěvek od kronholec.sk »
oco13 píše: ned úno 18, 2024 5:24 pm Pekná micina, bol si v Novej Bani? 8)
Nie v Žiline
oco13
#102 Nový příspěvek od oco13 »
Aha tak toho predajcu nepoznám. :-/
ladiki
#103 Nový příspěvek od ladiki »
martinto, nevím, co znamená v zimě, ale spíš bude chyba ve filtru....
martinto
#104 Nový příspěvek od martinto »
ladiki keď je teplota vonku okolo nuly ale keď sa traktor zohreje už je to v pohode
a filter som dal Donaldson P552483
Fry
#105 Nový příspěvek od Fry »
kronholec.sk píše: ned úno 18, 2024 3:25 pm Obrázek
to je tento?
https://www.youtube.com/watch?v=Nar6hwlEVfQ
Zpět na „Asijské stroje“
